Associate ports with an ACL
Associate ports with an ACL to apply filters to port traffic.
A port can be part of two different ACLs of different types: IPv6 and non-IPv6.
  • The ACL exists.
    enable
    configure terminal
  2. Associate port interfaces with a particular ACL:
    filter acl port <1-2048> {sub-port]][,...][slot/all][all]}
  3. Remove port interfaces from a particular ACL:
    no filter acl port <1-2048> {sub-port]][,...][slot/all][all]}
Variable definitions
Use the data in the following table to use the filter acl port command.
Variable
Value
<1-2048>
Specifies the ACL ID.
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
